7 members (UtahYork, MickeyP, Gdads51, Cletus1950, TexasJim50, Hotrod Lincoln, baldeagle),
105
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Need to remove and lube or replace knob and cable. I don't have an assy manual. can someone tell me how the knob/cable is held in place on dash? 1963 pickup. Thanks
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | I have found it is easier to lube them in place being they are mounted so you can push and pull the cable easier, I use kroll oil or marvolus mystry oil, unhook the choke from the carb, soak it all down let it set for a day or two then go wear your arm out pushing and pulling, if you still want to remove it though it is (mine anyway) put on with a nut on the back that you have the feed the cable through, and some have a stabliser mount on the firewall. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's a nut on the back side. Unhook the cable from the carb, loosen the nut and pull it from the dash, Scott | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thanks guys but getting at that nut is easier said than done. I wonder if I could just gently pull the gauge panel out and let it hang and then reach around that way? what do you think?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | To pull the guages out, you have to disconnect the speedo, and intermediate harness....alot more work than one nut on the choke cable if you ask me. I lay on the floorboard and use a box end wrench, take you 2 min and the choke cable will be out. Like 48BIGTRUCKS said, disconnect from the carb first. | | |
