Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, Hanks custodian, Ponchogl, rfs56trk, fonz8261), 36 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#78396 06/04/2007 4:18 AM
Z
ZB3
Offline
Z Offline
I need to change to an open driveline but can not seem to find a decent rearend for a decent price. Because of gas prices I would like to get a 3.08 or so ratio. I am going to run a 283 with a TH350. Can the center pumpkin be changed out of my torque tube rearend and what do I look for? Thanks, Wayne
#78397 06/04/2007 4:37 AM
If you'll do a search you'll find that later "pumpkins" will bolt to your housing but you'll have to mount your housing solid. It now is hinged.
You won't find one with a 3.08:1 ratio that will bolt in though.
#78398 06/05/2007 12:49 AM
3.38 will be as high as you can get for the '55-'62 3rd member needed for that conversion.
Bill Burmeister
#78399 06/05/2007 1:35 AM
Longbox55..or someone else: I'm putting a 56 pumpkin in my 52 and eliminate the torque tube so I will be going from a 4:11 rear end to a 3:90 .....what does a 3:08 come out of in 55-62?? A car??
#78400 06/05/2007 3:02 AM
Most likely, it'll be a 3.90, the most common gear in a '56. There was a 3.08 used in cars, starting in '58, but that 3rd member will not swap into the truck housing. There is a considerable differnce in not only the size of the housing and gear, but the shape is different, too (round for truck, flattened oval for car).
I would strongly suggest an overdirve trans with the deeper gear, be it a factory od, T-5, or a 700r4. That would give the best of both worlds, low rear gearing for in town driving, then a higher final gear for highway driving.
Bill Burmeister
#78401 06/05/2007 3:16 AM
ZB3
A good combo you might look at would be a 70s Camaro/Nova. This is a good rear-end for use in an AD truck, the ratios are commonly 2.73-3.73, with higher gears available and they are the correct width for your truck. They have leaf springs, but the perches won't work with your springs. I bought a leaf spring set from Total Cost Involved. It was an easy bolt-in. Good luck.
~Jim
#78402 06/05/2007 3:34 AM
Late '50s and early '60s GMCs offered a 3.07 but it is a spicer and won't mate to the corporate housing. You'll need to replace the whole rear end and change the mounts, but you'll keep the 6 lug pattern.
#78403 06/05/2007 6:11 AM
Z
ZB3
Offline
Z Offline
Thanks everybody for the responses. I am still looking for a good fit. I have a possible line on a mid 70's 3:43 rear out of an El Camino. I think the width will be right. I already have the 283 and 350 trans. Right now it is only the frame in the garage that I am getting ready to paint and start the assembly of the truck. Next to tackle is the frontend. Have a terrific day, Wayne
#78404 06/05/2007 10:09 PM
Wayne, nice to see someone on this end of the country. How long have you lived in K. Falls? I was there '78 - '82 going to school at OIT. Good luck with your project.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
#78405 06/06/2007 3:34 PM
Z
ZB3
Offline
Z Offline
Allan,
I grew up in K Falls and left in '77 and moved back 10 years ago. It is a great place to raise a family. You have a great looking truck. Right now mine is just a pile of parts. Have fun working on the old truck, Wayne
#78406 09/13/2007 4:27 PM
On the subject of rear end gearing, I am also about to tackle a rebuild of the 3rd member. When I look for rebuild kits, they have different sizes, ranging from 7.5 to 9.0, for the GM 10 bolt rear end. If I have a '58 3.90 from a truck, how do I figure out the last number? Is it the height of the ring gear?
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
#78407 09/13/2007 6:53 PM
The rebuild kits are usually listed by ring gear diameter. The old drop out 3rd member Chevy truck axle (1/2 ton) is a 9.375". One place I can suggest for parts, if you can't find them from the flaps or online, is Patricks. They do carry complete (w/bearings) and lite (no bearings, just gaskets and seals) kits. They also have the spanner wrenches and dial indicator sets for setting the pinion depth and backlash.
Bill Burmeister
#78408 09/14/2007 11:33 PM
Leo Offline
Moderator
Moderator
Very interesting thread. I will be changing my tranny, drive shaft and rear end. My truck had a 4 on the floor and I plan to install a 3 speed manual with overdrive and I already have a rear end with the 3.07 gears out of my 69 chevelle. I probably need a different rear end. I have a lot of learning to do before all this takes place.
#78409 09/15/2007 2:07 AM
So, can you fit any sized gear smaller than the 9.375" in the same housing? Or do you have to match the housing with the gear size?
Webshot Photos
#78410 09/15/2007 2:37 AM
No, the housings are designed around the specific ring gear being run in them, they don't interchange.
Bill Burmeister
