6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#78367 06/03/2007 9:28 PM
Well, this has probably been covered before.
I have a 283 that needs a new rear oil seal. I don't need to take the crank out, but would like to get this in. Can I loosen the bearing caps and raise the crank slightly to slide in the new seal? Then re-torque the mains. I believe this is a two piece seal.
Any tips I can use here is really appreciated.
G in Michigan
GS
#78368 06/03/2007 9:59 PM
sovagary,
Don't hold me to this, but I think there is a readily available one piece rear main you can stick in. This would of course require a naked crank flange to do.
Stuart
#78369 06/03/2007 10:53 PM
Riding in the Passing Lane
The early 283 engines had the rope type seal. They are ornery to put in. If it has the rubber seal you can drop the pan & rear main cap & roll it in.
1972 Chevy c10 Cheyenne Super
#78370 06/04/2007 12:13 AM
I put a rubber two piece in my 235. What I did was put one half of the seal in so that it stuck above/below the machined surfaces where the cap goes. Same with the other half.
Its difficult to describe but the seal to seal mating parts were staggered so that they were not in line with the seam between the cap and the block. I guess you could say the seam of the seal was at 2 o'clock and 8 o'clock. This prevents any oil from getting between the seal mating seams and leaking out thru the cap and block.
Its a small point but it was told me by a fellow who rebuilds engines in a machine shop.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#78371 06/04/2007 1:40 PM
I put them in my 283's. The rope seal may be pinned in place making it nearly impossible to get out. They are tough to get out when you hav eth ecrank out.
I would say the you could try it, but be prepared to go deeper when you do.
