5 members (Truckin39, tclederman, Gazz, Wally / Montana, lumbersawyer), 101 guests, and 2 robots.
Topics128,092
Posts1,056,461
Members48,443
OK folks...before I attempt to break something, does anyone here know for sure the rotation on the lugs for a 1.5 ton '46? Lefty/loosie -righty/tighty on both sides or did they do the wacky opposing rotation thing? Thanks in advance.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Not sure what your truck has. But sometimes the nuts with left hand threads will have an "L" stamped on them.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
3B Offline
Hy Tango, your truck probably has Motor wheels and Motor wheel nuts (large washer under the hex of the nut), they are standard right hand thread, hope that helps.
Thanx All --- just hoping to avoid busting something.
My 46 2 ton was normal rotation, rusty as all get out, but normal threads.
I only recall the 50's Buicks having LH threads on the drivers side only. Maybe others but thats all I've experienced. A strange arrangement for sure. Never saw it on trucks
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
My '59 F-350 has them. I don't remember if my Internationals do or not.
Dodge and Plymouth cars of the 50's and 60's were also set up that way.
Rich
1947 Loadmaster
All three of my 2-1/2 ton TF trucks have 6-lug Budd Wheels with left threads on the left side. The studs are marked with a "L" stamped on the end.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks to all. With no threads exposed and no apparent markings, it's really hard to tell which way they go. Will just have to proceed with caution. I' will relay what I find...hopefully without snapping anything off first.
My 38 1 1/2 ton both sides left loose right tight.
If you want to be extra careful split one of the nuts to remove it, then you can check for sure what thread it is.....granted you will need to find another nut...but a lot easier than replacing a stud.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
my 41 1.5 ton has RH threads all around
Thanks again to all. Just yesterday confirmed they are all "righty-tighty" (normal)on both sides.
