8 members (Gdads51, Rusty Rod, klhansen, 2-Ton, Bills54, Steelonsteel, stoveboltgator, dt235sd),
132
Mod | | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | 1st time I drove my 64 C10 at night I found the old style bulbs weren't all that bright.
Besides the Halogen direct replacement bulbs are there any other options out there for good looking and bright headlights?
Wonder if any enterprising company has developed any hi tech replacement lights for the 60's trucks yet? | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | The first headlight upgrade should be the installation of relays, regardless if you change to hi-tech bulbs or keep the originals. They make a huge improvement in light output. Here's a link explaining how I did mine: http://67-72chevytrucks.com/vboard/showthread.php?t=387693&highlight=headlight+relayI run halogen hi-beam bulbs but regular sealed beams on the low circuit. Halogen sealed beams burn out faster than any other bulb on the market, and I run with my lights on all the time. The halogen high beams don't get used near as often so they last a reasonable amount of time. | | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | Thank you for the schematic.
I think I will be swapping out the old sealed beams to the Projection Lamps out of a Jeep.
Since I need to rewire for relays I might as well get some lamps that you can see with. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Check the clearance behind the bulbs. I went to add an aftermarket set and there was not room. I'd have had to cut holes through the support.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | I have a 66 gmc and found halogen bulbs at O'Reileys for $7.00 each, wired them up with relays and now I can actually see at night.......Kieth
ps also bought new sockets with pigtails and wired them in......no muss no fuss just a lot of light.
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | Man I saw Halogen bulbs at the O'Rileys where I live and they wer $25.00 a piece.
Sure glad the pic-a-part had a $10.00 day last weekend. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I bought a pair of the "supposibly" high powered tri-bars at a show for 42.00 They do work quite well. | | |
