6 members (Jeff Ogden, TexasA&M48Truck, tclederman, cmayna, Jay R, 1 invisible), 48 guests, and 5 robots.
Topics128,012
Posts1,055,313
Members48,419
#782295 09/20/2011 7:09 PM
I am having a problem engaging 1st and reverse on a Muncie rock crusher. I believe you stick a philips screwdriver in a hole in the shift linkage, this aligns the shifter and you adjust the arms to fit?
any advice?
The actual rig pin is a piece of 1/4" drill rod, but a #2 Phillips screwdriver is a pretty good substitute. It aligns all the shift levers in the neutral position. Then, make sure the trans shifters are all in the neutral detent, and adjust the shift rods to drop into the holes easily.
Ran into a little problem and will have to redue the job
this morning. Too embarassed to tell.
C'mon now fess up. A little ridicule is good for the sole. grin
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Taint fessing up other than to say I only have R-1st and 4th working
Kinda a big jump without 2nd and 3rd. Tomorrow is another day.
Progress report. Well today I got 3rd back
Tomorrow I will go for 2nd. Oh wait, I have a show I will have to slink into.
Are you running the muncie off a floor shifter or the coloumn. Im still trying to work out the fine details, but im putting a 427 in my 63 in the spring and a muncie m22. I plan to use the coloumn shift for 1-4 and install a gate shifter for reverse on the floor.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
