1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | I've got a stock 1953 Chevrolet I6 radiator in my truck with a 87 350 v8. is the stock radiator ok to keep in there. right now i dont have any sort of fan in the truck but looking at buying electric fans. If i buy electric fan set up will that help any? or will i still have to buy a new radiator Thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It will be largely dependent on the condition of the radiator. Mine held for quite a while but eventually the pressure made a pin hole in it. There are several aluminum radiators available. I got a Champion off epay. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've run my '56 long and hard with a 350 and stock radiator. I have an electric fan with shroud. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If the radiator is in good shape I think it'll do the job unless the engine is sitting mighty low in the frame for whatever reason. There is another thread here about a bolter buying a new aluminum radiator for 159 bucks from eagle manufacturing. Might be agood investment since most shops charge a lot more than that to vat and rod one out. | | |
