2 members (Barry Martak, Wally / Montana), 167 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
1 Offline
I've got a stock 1953 Chevrolet I6 radiator in my truck with a 87 350 v8. is the stock radiator ok to keep in there. right now i dont have any sort of fan in the truck but looking at buying electric fans. If i buy electric fan set up will that help any? or will i still have to buy a new radiator
It will be largely dependent on the condition of the radiator. Mine held for quite a while but eventually the pressure made a pin hole in it. There are several aluminum radiators available. I got a Champion off epay.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I've run my '56 long and hard with a 350 and stock radiator. I have an electric fan with shroud.
If the radiator is in good shape I think it'll do the job unless the engine is sitting mighty low in the frame for whatever reason.
There is another thread here about a bolter buying a new aluminum radiator for 159 bucks from eagle manufacturing. Might be agood investment since most shops charge a lot more than that to vat and rod one out.
