4 members (Otto Skorzeny, rfs56trk, Bill Hanlon, 1 invisible), 81 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
DR
Offline
I definitely have a 55-62 block and a 41-54 water pump. By viewing the Links and information sent to me by Brad Allen I see what I do need is the attachment plate. I got this truck literally in a basket, or should I say numerous baskets.
I went looking today for a water pump that would move the fan up 2 inches. None to be found.
If you or anyone else knows of just where I can get the attachment plate, it would be very helpful.
I sent you the link here is the eBay item number (not mine) for reference, they are $40 #140456073982 I believe Jim Carter sells them as well. The document I sent you was put together by these guys.
DR
Offline
Thank-you for the information, I just might get this together this year.
DR napa part numbers are WP58125 for 5/8" pulley and WP58126 for 3/8" pulley hope this helps
You do realize that you have to use a 216 water pump with that adaptor plate.
Pete
I went to the wrecking yard and bought an auxiliary electric fan for 30.00 and mounted it in front of the radiator, on a toggle switch.
Quick, simple and easy.
If it is the narrow belt,use the 1953-1954 235 car water pump.Napa part number 58-126
Tim
1951 3100 Chevrolet
Pete
Pete,
People with some older-style water pumps from non-216 engines might think (from your helpful suggestion) that they need a 216 pump.
When using the adapter plate, you would need to use a water pump for a 1955-1st series or older truck engine.
That would include:
- all 216 engines
- 1941 through 1955-1st series 235 engines
- 1954 and 1955-1st series 261 engines (a sometimes special, but older style water pump that is hard to find)
As Tim posted above, you would want to choose a year that had a pulley on the water pump that matches the groove-width on the block's generator and harmonic balancer.
1953 to 1955-1st 235 and 261 engines had narrower fan belts than used on earlier 235/216 engines.
You are right Tim,I keep forgetting that the 41 to 55 235 truck engine used the same pump as my 216.
Thanks,Pete
