7 members (klhansen, frogfarmer, Gdads51, Hotrod Lincoln, 1955 1 Series, Goach2, 1 invisible), 106 guests, and 3 robots.
Topics128,198
Posts1,057,269
Members48,466
The cable coming from the Turbo 400 transmission in my '66 Chevy C20 needs a place to attach. It has a spring and a slotted connector on the end of it. Where and how does this attach to the carburetor? It was not hooked up when I bought it from the previous owner, however I would like to get it connected properly. Thanks for your input.
Tony
What kind of carburator you running and do you have the cable bracket that holds the cable sleeve in place?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I thought the turbo 400 used an electrical solenoid for the down shift, does it also have a detent cable? Been 20 years since I have looked at one. But I don;t remember any other cable other than the speedometer cable. Guess I better go look at one.
If the modulator is on the right side of the transmission, it is a TH400. I have never seen a TH400 with a cable. The TH 350 has the modulator on the rear of the transmission, and does use a cable.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
Thanks for the input. According to the previous owner, it is a Turbo 400, however per this information it is a Turbo 350. In any event, I would like to properly hook up the cable coming out of the passenger side of the tail shaft. Also, I would like to know what it is. The truck drives and shifts very well without it, however I want to do it correctly.
The carburetor is a 600 cfm Edelbrock with an electric choke. I do not have the cable mounting bracket nor do I know what it looks like.
I will double check the pan shape and I appreciate the cheat sheet on tranny pans. It is a good quick reference piece to identify tranny types.
Tony
Riding in the Passing Lane
The cable is a kickdown cable. Passing gear. They have universal brackets for mounting it. Summit or Jegs lists them in their catalogs or one of the local speed shops probably does too.
1972 Chevy c10 Cheyenne Super
H Online: Content
"Passenger side of the tailshaft"- - - - -The only thing back that far is the speedometer cable. The kickdown cable attaches to the transmission housing above the oil pan, close to the dipstick tube. Its only function is to allow a 3-2 downshift when passing. The modulator controls shift points and part-throttle downshifts by responding to intake manifold vacuum.
