5 members (Uncles51, Millenimech, Chip O, Peggy M, Hotrod Lincoln), 82 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#778401 09/06/2011 1:17 AM
Check out my progress on my crew cab LCF I am building. http://rides.webshots.com/album/580587250vqfuun
It is going really well so far. Hoping to have it in finish primer by the end of September and ready to set on the chassis
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Nice work !
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Looking good! Are you going with suicide doors?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Yes I am going with suicide doors in the back. Always liked them. Going with electronic safety locks since my little ones will be back there most of the time.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Buggy, you got all the talent man. Looking good. Please keep us posted.
Buggy Great work. what did you use for the roof? IS it the originals with extension to make them matchup? Also any pictures of the how the "B" pillar was installed for fron of the rear door?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
the roof is off a panel truck. I cut it at the a pillar 1/2 way up the windsheild and used the door frame of the panel to match up to where I cut the original b pillar off down low. I left 6 inches of the panel truck on the b pillar. I then took the original b pillar from the cab over and flipped it side to side and used it as the back part of the b pillar. My rear doors are two doors that I used the rear portion of both so it would line up with the shape of the flipped arounf b pillar. The rest of the roof was the back portion of the panel roof. I think I cut about a 2 foot chunk out of the middle. The two roof halves did not quite match up so I had to slice and shrink the rear section to fit. I also had to trim it to match the rear of the truck roof of the second cab since htey were a slightly different shape. Its kind of a learn as you go process. I do not have any pictures of the b pillar but once it is completely installed I will gat a few posted. I am trying to get the entire passenger side put back together than start on the driver side. I did not even start on a door for that side yet.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
