2 members (Shaffer's1950, 1 invisible),
36
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Check out my progress on my crew cab LCF I am building. http://rides.webshots.com/album/580587250vqfuunIt is going really well so far. Hoping to have it in finish primer by the end of September and ready to set on the chassis | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Looking good! Are you going with suicide doors? | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Yes I am going with suicide doors in the back. Always liked them. Going with electronic safety locks since my little ones will be back there most of the time. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Buggy, you got all the talent man. Looking good. Please keep us posted. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Buggy Great work. what did you use for the roof? IS it the originals with extension to make them matchup? Also any pictures of the how the "B" pillar was installed for fron of the rear door?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | the roof is off a panel truck. I cut it at the a pillar 1/2 way up the windsheild and used the door frame of the panel to match up to where I cut the original b pillar off down low. I left 6 inches of the panel truck on the b pillar. I then took the original b pillar from the cab over and flipped it side to side and used it as the back part of the b pillar. My rear doors are two doors that I used the rear portion of both so it would line up with the shape of the flipped arounf b pillar. The rest of the roof was the back portion of the panel roof. I think I cut about a 2 foot chunk out of the middle. The two roof halves did not quite match up so I had to slice and shrink the rear section to fit. I also had to trim it to match the rear of the truck roof of the second cab since htey were a slightly different shape. Its kind of a learn as you go process. I do not have any pictures of the b pillar but once it is completely installed I will gat a few posted. I am trying to get the entire passenger side put back together than start on the driver side. I did not even start on a door for that side yet. | | |
