5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
Page 46 of 177 1 2 … 44 45 46 47 48 … 176 177
I'll give it a try Dad.
Robert, I thought you put the carb back on.
Came across a sweet deal on a polished tpi setup that I couldn't refuse!
Robert C.
I'm a Genius in the making.
1950 3600
Originally Posted by 1Bad51
Looks awesome Rob !
Thanks Tab!
Robert C.
1950 3600
Troubleshot a wiring problem(self inflicted) got my brake lights working.
Adjusted the parking brake function on my rear calipers too.
Hey..even the foot pedal holds now! yahoo
More pix on Flickr.
Well once again I'm a few days late with this. I got my truck back from the body shop on the 18th and spent the 19th, 20th and 21st putting it back together. We were able to make it to the Frog follies in Evansville, IN this past weekend. I had it weighed (3200 lbs) and passed the safety inspection. It was such a joy to drive and with a few tweaks here and there we plan on going to Shades of the Past in Pigeon Forge, TN on Sept. 9th. I know it's just in primer but I plan on tearing it down this fall/winter for final paint. Check out the build link for new pics.
That's looking real sharp Gman! thumbs_up
More pix on Flickr.
Today, the Farmer next door lit a huge fire , smoked half the district out .
So I went out. Went to a friends place a few miles away, he wasn't home , so while I waited for him to get home, I gave the truck a birthday and adjusted the valves, a job I've not done for a few years.
Truck is noticeably quieter now smile I'm really pleased I thought to do that job.
C4 Offline
Got the cab and everything stripped off the frame for cutting. Be posting up questions on the best way...... tks
We lust for what we want, and weep for what we need.
E-brake is now working. It took a set of custom ordered cables from Lokar to get it right, but now works like a champ.
E-brake in cab
http://s783.photobucket.com/albums/.../?action=view&current=ebrake829B.jpg
Cables at transmission mount
http://s783.photobucket.com/albums/.../?action=view&current=ebrake829C.jpg
Cables at caliper
http://s783.photobucket.com/albums/.../?action=view&current=ebrake829A.jpg
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Yesterday got EVERYTHING but the hood sandblasted. The guys had a mobile setup and did a great job at a great price. Took them 3.5 hrs, they used about 35-40 bags of sand but charged me for only 15.
All said and done, $450 + taxes. (CDN)
Have some a ton of pics (of course) and some video taken as well.
The sandblasting shots start here:
https://picasaweb.google.com/113636046886857960240/Frame#5646406298535427074
(you can click the big right arrow or use the right arrow key on the keyboard to navigate)
Some video of the cab getting blasted here:
https://picasaweb.google.com/113636046886857960240/TruckVideo#5646430172482726114
and frame here:
https://picasaweb.google.com/113636046886857960240/TruckVideo#5646459371228629346
Bigtonka, did you ever look into renting a sandblaster and doing it yourself? I am just wondering how the prices compare as I have not seen a business like that in my area. Looks great though!
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
Yes, I had all the equipment reserved and two days before I decided to go pro. I really wanted to do it myself as well.
You need a diesel generator to supply the air. That was $80 per day, then a 100lbs pot was $80. So taxes, you're at $200 in rental equipment. The sandblaster you rent is nowhere NEAR as powerful as the one they use. So double the time they took, if not tripple.
I think I threw the towel in on doing it myself when the air compressor I was renting needed a clevis hitch to tow it back to my place.
Based on what I've read on this site, and the mess I've experienced doing small sandblasting, I decided to get a pro to do it.
It was messy, and they had the setup to get it done fast. So I add my name to the list of guys who say let the pros do it.
As for the portability of the guys, look under professional washers. Lots of companies have their buildings cleaned with sandblasting, graffiti removed etc. The whole setup is in the back of a 25' truck.
WOW! That's a kewl business idea... wish we had that kind of service here too.
Great pics and video!
Thanks for sharing!
Thanks for sharing!
Thanks Jerry, I guess I was under the impression that this is available everywhere. Maybe you can be the first in Texas!
They have a giant hopper in the truck with a HUGE diesel engine in the front half. A pallet of sand that one guy keeps feeding into the hopper and adjusting the pressure as the guy blasting gives hand signals.
Thanks Jock, The AD looks like it's coming along nicely. It looks Great!
Today was rough - felt like I've hit the "truck restoration wall"...
It was a full day of applying epoxy primer to the cab, doors, fenders, bed parts and everything else.
Got it all done, but not without first blowing the start capacitor on my compressor because I had the generator setup wrong, then forgetting the dam paint at home after getting all set up.
But it's all shot now and protected from rust. smile
https://picasaweb.google.com/113636046886857960240/Cab#5647198343668027858
More photos there - just scroll...
A good day's work.
Last year back home in Greece I was given an estimate of 700 Euro plus 21% tax( about 980 Dollars + tax)for frame and cub and I even had to bring it to them... :mad:
Jianis
Last night, after almost 15 years of sitting, I started the engine in my '53!
It was a very good day!
Wish I could say it fired right up. First I cranked and cranked and nothing. Then decided it wasn't getting gas from the new tank, lines and pump - but when I removed the line at the carb (also new) there was plenty of gas. Next checked for voltage at the distributor and had it there. Took apart the new 15 year old distributor thinking maybe it was corroded after all these years and it looked brand new. Then it hit me to check for voltage at the distributor while cranking and sure enough as soon as it started to crank - no voltage. The ignition switch was wired wrong. Fixed that and bingo fired right up!
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Jianis
Greece must be looking for $$$ wherever they can find it. Better stay in Holland. LOL
~Jim
Hooland is also expensive 2 years ago when I was rebuilding my 48 Fleetmaster (passenger car) they asked me 400 euro plus 19% tax for the frame. ohwell
Jianis chug
Just finished replacing the other broken window, the driver's door window!
Hopefully I can fix the taillights. Recently rewired them but not lighting up. ohwell
After that it's off to the body shop to replace those rotted floors and then the DMV for plates!
Dave Baird
1951 Chevy 3803
1 Offline
Man... The frame really looks awesome ! What a great job Mark, But them legs??? big_eek
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
LOL! Thanks! My kids thought I was wearing tights!
Originally Posted by Bigtonka
Painted the frame, dump box frame, inner fenders etc today... As of this point reassembly begins!
I may of rust proofed my legs... a little... a reminder of why I shouldn't spray paint in the wind.....
Looks great Mark, your last comment reminds me of another thing you shouldn't do against the wind......
At least if you did,your legs wont rust! wink grin
More pix on Flickr.
Very true!
Thanks, by the end of the day I hope to have a rolling chassis again.
Leo Offline
Moderator
Moderator
Had to take out the steering column to get the steering box looked at. Had to loosen the inner fender, take out the fender to cowl brace and the driver's seat. The rest was easy. (easier than I had envisioned)
Wheel Studs exchanged for bigger and better, no thanks to FLAPS.
I am so tired of dealing with part store “professionals” who cannot find a pine scented air freshener without first knowing what size motor the vehicle has that it is going in and weather it has power steering and air conditioning.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Left the headlights on and somehow managed to fry my 5 year old Optima battery due to total deep discharge. So I ran around and purchased and put in a new battery today. grrr. 6V batteries are gettin' hard to find around here.
Kurt
I took advantage of some 90 degree temps and hit a good lick on the cab today.
Cut out the old carpet, removed the incorrect seat, removed the gas tank and vacuumed the floor. Found a few goodies and a buck or so in change... nothing old though... bummer.
All this revealed good, solid floor metal... no rust throughs anywhere YAY!
I also use an Optima. When I got it I made some research as they are very expensive here in the Netherlands and I remember it was mentioned that if it gets totally discharged the only way to bring it back to life is charging it with high Amperage (about 100A) for 20 minutes
Jianis
I put an Optima in but didn't really need it for 2 years. When we tried to start it the thing was dead. I took it back to Interstate where I bought it and because it was over 30 months old and was an Optima I got no replacement. Leaving it sit for too long must be hard on them.
~Jim
I am surprised from my car battery back home.I go back 2 or 3 times every year.In the winder I am away for 8 months.My battery is 6 years old. I am mostly in a harry so I often have no time to charge it.So far It always starts. smile
Jianis
I decided to change the battery box from this to this.
Robert C.
1950 3600
Got the running board to cab seals done,passenger side running board,splash apron and rear fender fully fitted with all stainless hardware..
Finally managed to get the neutral safety switch working on the steering column, I had the wiring info all along,in my TH350 rebuild book....!
Sussed my brake light problem too, a dead wire...now fixed, those LEDs are really bright!
More pix on Flickr.
Pulled the gas tank (Tiny was right - full of rust). Gonna' get everything cleaned up Monday, then order parts I need. Try to ship tank to KY sometime this week.
today was GREAT! i cut out my original firewall and fitted my "Direct sheetmetal" 4" recessed firewall in its place. currently it is held in place with clecos but I will weld it up this week!
pix are in my album
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Today was a Dust, Mud and Dinosaur Blood day. I spent a couple hours with a wire brush, degreaser and a rag and cleaned 60 years of grime off of some of my engine components.
Oil filter before
Oil filter after
Generator before
Generator after
Fuel pump before
Fuel pump after
Distributor before
Distributor after...need a smaller brush to get into the nooks and crannies
I also pulled the oil pan off my newer 216 to check out the bottom end.
Dallas Huybregts
Sherwood Park, Alberta
1951 Chevrolet 1300
email
Photobucket
flickr
Modified throttle linkage to get around Fenton headers, mounted under bed spare tire carrier. Took a short test drive, just need exhaust then ready for cruisin'!!!
[IMG]http://i171.photobucket.com/albums/u320/durwoods78/1959%20Chevy%20Apache%203600/SAM_0370.jpg[/IMG]
Got the drivers side running board ,splash apron and rear fender buttoned up.
For the last time for a while...(I hope!)
More pix on Flickr.
