| | | Forums66 Topics128,105 Posts1,056,208 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 74 | Folks -
We got Matilda home from the ranch after having some help knocking out dents in the roof of the cab. Need to replace window regs and door parts. Are the cabs and doors, etc the same btw 1 tons and the lighter trucks? LMC and a couple of other vendors I called pretty much blew me off and said to check with a mechanic. Durrr... Also, door glass? I'd appreciate anyone that can share the finer points. She's a 47 AD...
TIA,
John | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the cabs and any related pieces like door internals are the same on any conventional cab for the year .... front clip is the same 1/2T to 1T, fenders change for the 1.5T and up
Bill | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Everything on the cab, for every AD truck, unless it is a COE, interchanges. 1.5 & 2 tons the front clip changes. | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | 47-50 doors are the same 51 doors are unique 52-55S1 doors are virtually the same but some odds and ends for the 54/55S1 are different
Front fenders are same 47-53 1/2 to 1 ton, 1 1/2 to 2 ton 54/55S1 are the same just as the older
Beds are same 47-53 54-55S1
Hoods are interchangeable for 1/2 - 1 tons but emblems change and '54-55S1 will bolt on the older trucks but the front emblem mount is completely different, same as the 1 1/2-2 tons
Probably some other odds and ends, too. | | | | | Joined: Oct 2011 Posts: 34 New Guy | | New Guy Joined: Oct 2011 Posts: 34 | i see that LMC and like them only care about 1/2 ton and 3/4 ton but 1/2 3/4 and one ton are lite,duty trucks , no one not remaking the one ton emblems or the emblems for the trucks that had the campers on the trucks | | |
