7 members (Peggy M, walter74, moparguy, NJC, HandyAndy, Oswald, 1 invisible), 137 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#777231 09/02/2011 1:22 AM
My barn doors will open while I'm driving
Cam someone tell me is the handle on the inside spring loaded?..thus keeping the upper and lower hooks in place..There is no spring on the inside handle on mine leaving it to jiggle open..
1946 chevy 1/2 ton panel
1937 ford coupe
I went and looked again at my doors and saw there was only 1 spring, runnunig up and down on the back side of the handle. Don't know what I was thinking before. There are also set screws for the hooked rods. It looks to me that if the rods are not adjusted to the proper angle to catch and then clear at the top and bottom, the door will be loose. The set screws are important to keep the rods in place. I am missing one and the door doesnen't pull tight as it should.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Thanks MikeE...Does anyone know where I can buy a spring
that is located on the back side of the handle on barn doors
1937 ford coupe
at a hardware store? there are no panel-specific parts sold at any of the repro vendors
I'm probably all wet here but just trying to help. I don't know if your 46 is anywhere like my 52 panel but here is a couple shots that may help.
This shot is the middle handle and it does have a spring on it.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelBodypics007-1.jpg
This is a shot of one of the left door latches that go at top and bottom. It does have spring that hooks to the little catch but unfortunately the pic don't show it...if you look real close you may see it betweent the two tall pieces of metal..
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelBodypics005-1.jpg
This is just another pic to maybe help. This is a pic of the right door latch and it does have a spring to. This is the latch the door handle goes through.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0161.jpg
The new springs I used on the LEFT door did come from Ace Hardware.
I might add that when I took my panel for the first ride up the street the rear doors came open. My latches with springs were fine. The problem was I needed to adjust the "catches" that fasten to the body at the top and bottom AND I added a small gasket (homemade) between them and the body which help accomodate for the wear on the catches and the little latches them selves. All is fine now.
Yours may be totally different from yours but if it helps in some little way I've done my job smile
This is a shot of the intire rod assembly layed out. Just veiw it full screen.
Those are great pictures. The latches on the 46 though hook horizontally where yours appear to hook vertically.?? This thread motivated me to take my door handle latch apart, and it is exactly like your picture. This could mean the original was replaced by a later model. I did learn wher the spring goes and what it looks like.
1946 1-ton Panel
Alvin do you have a picture of the door catch on the opposite door?
1946 1-ton Panel
Mike, my oposite door only catches right in the middle. The door latch "tongue" catches on the striker plate in the center of the left door.
I'm gonna take a look at my photobucket and see what I can find and list it below. Maybe, just maybe it'll help.
This is my right door latch.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0281.jpg
My right latch catches on this striker plate on the left door
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0282.jpg
..and this is the right door "guide"
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0280.jpg
that fits into this on the left door.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0283.jpg
These are the "catches" that fit at the top and bottom of the left door. You can see they are labeled top and bottom.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Reardoorcatches.jpg
And the next two pictures are from some pics of my friends panel as I needed to know what went where because mine was all apart.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Reardoorcatches002.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Reardoorcatches001.jpg
Hey, I may as well throw in a pic of the LEFT door center stuff.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Reardoorlatch.jpg
All these photo's and more are on the photobucket link under my signature line. Take a peek if you like BUT I do NOT know if my AD is anything like your 46 doors. (I like your rear windows)
I would like to post a pic of my 46 panel now that it is nearly
done..I don't know how....but I know how to send it to
another e-mail...could someone on the list then post it for
me... jd
1937 ford coupe
You can't post pictures on this site, you can only post a link.
Follow directions here or go to the IT short bus section in the forum.
https://www.stovebolt.com/ubbthread...lat&Number=766963&gonew=1#UNread
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
OK, I have sweat blood to do this, but I think I figured out how to get some pictures of my rear doors on webshots. They show the difference between the Art Deco Panel Door system aqnd the Advance Design.
http://rides.webshots.com/album/580819930UJpLXT
1946 1-ton Panel
Way to go Mike. Yep, they're different all right. But hey, you can do it. ONE piece at a time. We're all here to help.
Originally Posted by MikeE
OK, I have sweat blood to do this, but I think I figured out how to get some pictures of my rear doors on webshots. They show the difference between the Art Deco Panel Door system and the Advance Design.
Thanks for the photo-education, Mike
I took my latch apart today. I need to have some weld put on a couple pieces. Then I can grind and file the bolt and an arm so it all works again. At least that is the plan. I also have to make a setscrew for one of the locking rods.
The bigger issues are the body, rotted out door hinge fixtures and the multi board floor. Not to mention the rear doors.
1946 1-ton Panel
