2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
Looking for anyone who may have a camaro rear in a 55-59 pick up or panel. I have a 75 camaro rear in my 55 2nd gen. panel and would like to utilize the factory ebrake connection on the frame. Anyone have any part #s or suggestions. Thanks!
Y
Y Offline
I put a 79 camaro rearend under my 51 Burb, and I doubt if the E-cables are that much different, mine is drum type. Are you talking disc? I haven't figured out how to secure the cable housing to the backing plate. Don't the end attach to the frame/clamp brkt like the AD's? If they don't I could see where you might have a problem.
I'm not sure about the second series,but it might be worth looking at Lokar.
I used a mid 80's Camaro/Firebird rear in my AD and the Lokar cables hooked right up.
More pix on Flickr.
Riding in the Passing Lane
I have a Firebird rear end in my 58. It seems like I used the stock 58 cables in the FB backing plates.
1972 Chevy c10 Cheyenne Super
I have drums in the rear and check at napa for the correct length but could not come up with anything. Looks like ill have to go with a lokar kit or move the frmae mount location and go with the camaro e-brake cables.
contact control cables in santa fe springs, ca google them
1949 SUBURBAN
I have a set from Control Cables, '37 ends on one side, '79 on the other. Use the downloadable brake cable sheets, very easy to get what you want.
Joe
