2 members (dt235sd, 1 invisible), 114 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
#775188 08/26/2011 11:49 AM
Is there a tubeless 22.5, ten lug, 7.25" bolt pattern wheel out there ?
I thought it was said that in 55 chevy brought out tubeless 22.5 wheels with a ten lug 7.25" pattern.
I was talking to a junk dealer yesterday and he said yes to the 22.5" wheel but it comes as 6 lug wheel.
So I went to the gallery and looked at 55-59 big bolts and sure enough I saw 6 lug wheels.
So how did Chevy make it possible to chose the optional old style tube type 20" wheel, which would have been 10 lug with a 7.25" lug pattern?
Am I totally confused or what, because I have been looking for a 22.5, ten lug, 7.25" lug pattern, tubeless wheel.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
There is a 6 lug 20" FR5 firestone wheel. I have 2 that came on my truck
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Some info here
http://www.stovebolt.com/techtips/wheels/
Yes Chevy had 10 lugs on the 1.5 ton trucks in 56-59 and on the 2 tons they had 6 lug Budd in those years, then dropped the 10 lugs in later years.
Yes there are 22.5" wheels with 10 lug on 7.25" diameter bolt circle out there, they are not all that common though.
I've got a set on my truck and have seen a number of others, you've just got to keep looking.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Well thanks Grigg, I guess not many out there realize this and think that all 56-59 had 6 bolt wheels cause in talking with them I hear things like "ain't no such thing".
So if I hear you correctly, those wheels are only going to be seen on a 1.5 ton if they didn't chose the optional old style tube type 20" wheel.
That would make them uncommon, for sure ! Let me know when you see some more of them.
Dan
I guess I learned something also. I was not aware that the 1.5 ton had the 10 lug. I have only been into big bolts for a short time and all I have seen is the 6 bolt 55-59. thanks Grigg
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
My 1956 1.5 ton has 10 bolt 20" rims.....
GMC: Get More Cash...
1958 GMC
My Webshots photos
Hey Grigg --- do you know offhand what the rim width for those puppies might be?
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
3B Offline
Hy guys, those 22.5" wheels were 5.25" wide, and the original p/n was 3724677, hope that helps.
I didn't know the part number, not sure if it'll do any good these days though?
Exactly right on the width, no other width available that I've ever seen or heard of with this bolt pattern.
Grigg
---All pictures---
Sounds like they might work as replacements for the 5" wide x 20" rims on my '46 1.5 ton...if I can ever find a half dozen of them.
