4 members (Hotrod Lincoln, KCMongo, Peggy M, eclector), 166 guests, and 2 robots.
Topics128,034
Posts1,055,533
Members48,425
#774991 08/25/2011 8:38 PM
School me here, I couldn't find the info in searches or FAQ. Are there any 1960's or later 3speeds (3-on-the-tree) that have the same side shift pattern as an early 50's car 3-on-the-tree? Looking to get to an open driveline using a truck BH in a car w/235 & Nova rearend.
Thanks.
'53 BelAir 261 3spd/OD 4dr
'54 3100 235 3spd
'79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually
'89 V3500 350/465/205 SRW CC
One Chevy just isn't enough.
DADS53 #774996 08/25/2011 9:01 PM
Unless I completely missed the point of the question, all three on the tree standard transmissions have the same shift pattern. If you happen to be talking about the automatic transmissions then the answer is no.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks FGT.
Yup, that was the Q.
So, I understand that all 3-on-the-tree transmissions from early 50's throuth late 60's have the same shift pattern. So, I could take a 60's 3spd, bolt it to a truck BH, then bolt that to a car 235 and use the cars' linkages. This could give me a quick way to connect to an open driveline if true.
Am I correct?
'54 3100 235 3spd
DADS53 #775027 08/25/2011 10:21 PM
the trans will fit but you'd have to modify the linkage between the shift box on the lower column and the trans [from the box up you need your 53 original stuff] - and you likely have to adapt driveshaft length .... if you can find a 68 or later 3 speed, they have syncro 1st
squeeze #776052 08/29/2011 6:52 AM
Really, that late (68). Good to know. I see 50's-80's 3spds on Clist a lot (cheap) and since I want the open driveline, this option looks good.
'54 3100 235 3spd
