| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | School me here, I couldn't find the info in searches or FAQ. Are there any 1960's or later 3speeds (3-on-the-tree) that have the same side shift pattern as an early 50's car 3-on-the-tree? Looking to get to an open driveline using a truck BH in a car w/235 & Nova rearend. Thanks.
'53 BelAir 261 3spd/OD 4dr '54 3100 235 3spd '79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually '89 V3500 350/465/205 SRW CC One Chevy just isn't enough.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Unless I completely missed the point of the question, all three on the tree standard transmissions have the same shift pattern. If you happen to be talking about the automatic transmissions then the answer is no. | | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | Thanks FGT. Yup, that was the Q. So, I understand that all 3-on-the-tree transmissions from early 50's throuth late 60's have the same shift pattern. So, I could take a 60's 3spd, bolt it to a truck BH, then bolt that to a car 235 and use the cars' linkages. This could give me a quick way to connect to an open driveline if true. Am I correct?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the trans will fit but you'd have to modify the linkage between the shift box on the lower column and the trans [from the box up you need your 53 original stuff] - and you likely have to adapt driveshaft length .... if you can find a 68 or later 3 speed, they have syncro 1st
Bill | | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | Really, that late (68). Good to know. I see 50's-80's 3spds on Clist a lot (cheap) and since I want the open driveline, this option looks good.
