| | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | I noticed on Sheridan's 46' web sight his OE brake/clutch pedal assembly has grease/zirk fitting on the pedals. I have seen 5 of the things and never noticed. I am rebuilding mine now and see no drilled and tapped holes for such. Seems logical and question this before. Something I need to modify? Cavebull | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its been a LONG TIME since I had my 46 but if you have the pedals with the bushings in them I would think it'd be nice to drill and tap for a zerk whether it had one or not. Seems like a good place for it.
Did you check the shop manual to see if it was mentioned or discussed in a repair section? | | |
