0 members (), 348 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
I noticed on Sheridan's 46' web sight his OE brake/clutch pedal assembly has grease/zirk fitting on the pedals. I have seen 5 of the things and never noticed. I am rebuilding mine now and see no drilled and tapped holes for such. Seems logical and question this before. Something I need to modify?
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Its been a LONG TIME since I had my 46 but if you have the pedals with the bushings in them I would think it'd be nice to drill and tap for a zerk whether it had one or not. Seems like a good place for it.
Did you check the shop manual to see if it was mentioned or discussed in a repair section?
