| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | I'm having trouble finding shocks to fit my 64 K10. The old ones are completely rusted out. The vendors i went to cannot identify a replacement that will match the size of the mounts which are original to the vehicle. Anyone have some direction on what current replacement shock will work offering a smooth ride. thanks john
1964 K10 Fleetside Pickup Truck | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | For my '65 c10 lwb... I went to the parts store and they looked 'em up.
The biggest pain was installing them when 3 of the 4 bolts broke getting the old ones off.
Have you tried the local parts stores?
-W
| | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | I've gone to my local Napa and Carquest shops. Napa couldn't even locate shocks for the rear....Carquest came back with one solution but they where close to $140 per shock. I think they're a bit expensive. The guy had to measure the old shock and worked backwards to locate what current shock matched. Im not prepared to replace the mounts to fit more modern shock fittings.
1964 K10 Fleetside Pickup Truck | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Anybody in here have any suggestions?
-W | | | | | Joined: Mar 2010 Posts: 76 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 76 | Rancho shocks ; the top is a boot not a tube but they fit and work. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I'm having trouble finding shocks to fit my 64 K10. The old ones are completely rusted out. The vendors i went to cannot identify a replacement that will match the size of the mounts which are original to the vehicle. Anyone have some direction on what current replacement shock will work offering a smooth ride. thanks john rancho are the way to go. i just have to did up the part nbr for you if you want . a can also supply the nbrs for the frt ones if you want ron | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | rears are RS5143 frts are RS5601 rancho ron
64K910 | | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | I got 4 Gabriel shocks from our local Auto Zone store.They took 2 days to get them in, they weren't that expensive plus a rebate. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I got Monroe shocks at Advance Auto...is there a big difference between '64 & '65?
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I used Monroe's but on the rear I had to grind the bushings in the lower shock end to make them fit. Once the bushing was flush with the groumet, they went right in. The fronts went right in with no problems.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | AC Delco. From my local flaps. Nothing fits like original equipment! | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The problem with the rear shocks on the 1/2 ton 4x4 and 3/4 ton 4x4 trucks, is the hole size. These shocks have a 3/4" i.d. mounting eye on the top & bottom and not many shocks are currently offered, in this configuration with the proper compressed length and travel. Here is what I use and the price is great: AC-Delco rear shocks for 4x4 | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | from the ad:
Rear Shocks
Chevy & GMC 4x4 Pickups Suburban Shock
This is for 2, Brand New, Genuine AC Delco rear Shocks for 1966 4x4 Chevy K10, K20 Pickups & Suburban. It also fits the 1966 4x4 GMC K15, K1500 Pickups. These shocks are originally for 1966 but can be used for other years as well. The AC Delco P/N is 508-30. The GM OEM part number is 22065254. | | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Thanks very much for the responses and support. Not sure why its been so hard for me here in upstate NY to find the right shocks. This is a huge help.
