4 members (Youngin' Tut 59, Jon G, fonz8261, MickeyP), 113 guests, and 2 robots.
Topics128,132
Posts1,056,383
Members48,441
#774389 08/23/2011 9:36 PM
I'm having trouble finding shocks to fit my 64 K10. The old ones are completely rusted out. The vendors i went to cannot identify a replacement that will match the size of the mounts which are original to the vehicle. Anyone have some direction on what current replacement shock will work offering a smooth ride. thanks john
1964 K10 Fleetside Pickup Truck
Socket Breaker
Socket Breaker
For my '65 c10 lwb... I went to the parts store and they looked 'em up.
The biggest pain was installing them when 3 of the 4 bolts broke getting the old ones off.
Have you tried the local parts stores?
-W
I've gone to my local Napa and Carquest shops. Napa couldn't even locate shocks for the rear....Carquest came back with one solution but they where close to $140 per shock. I think they're a bit expensive. The guy had to measure the old shock and worked backwards to locate what current shock matched. Im not prepared to replace the mounts to fit more modern shock fittings.
Socket Breaker
Socket Breaker
Anybody in here have any suggestions?
-W
Rancho shocks ; the top is a boot not a tube but they fit and work.
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
rancho are the way to go. i just have to did up the part nbr for you if you want . a
can also supply the nbrs for the frt ones
if you want
ron
rears are RS5143 frts are RS5601
rancho
ron
64K910
I got 4 Gabriel shocks from our local Auto Zone store.They took 2 days to get them in, they weren't that expensive plus a rebate.
I got Monroe shocks at Advance Auto...is there a big difference between '64 & '65?
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
I used Monroe's but on the rear I had to grind the bushings in the lower shock end to make them fit. Once the bushing was flush with the groumet, they went right in. The fronts went right in with no problems.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
k10 Offline
AC Delco. From my local flaps. Nothing fits like original equipment!
The problem with the rear shocks on the 1/2 ton 4x4 and 3/4 ton 4x4 trucks, is the hole size. These shocks have a 3/4" i.d. mounting eye on the top & bottom and not many shocks are currently offered, in this configuration with the proper compressed length and travel. Here is what I use and the price is great:
AC-Delco rear shocks for 4x4
Socket Breaker
Socket Breaker
from the ad:
Rear Shocks
Chevy & GMC 4x4 Pickups Suburban Shock
This is for 2, Brand New, Genuine AC Delco rear Shocks for 1966 4x4 Chevy K10, K20 Pickups & Suburban. It also fits the 1966 4x4 GMC K15, K1500 Pickups. These shocks are originally for 1966 but can be used for other years as well. The AC Delco P/N is 508-30. The GM OEM part number is 22065254.
Thanks very much for the responses and support. Not sure why its been so hard for me here in upstate NY to find the right shocks. This is a huge help.
