5 members (48jim1ton, Jay R, Jman, Peggy M, JW51), 91 guests, and 1 robot.
Topics128,042
Posts1,055,597
#773796 08/22/2011 3:55 AM
Hi,
I have a 66 c20 which has become almost a daily driver. The ball joints are original and completely shot, so I have saved up and purchased new upper and lower ball joints and am getting ready to swap them in. I am thinking while I am i there I should also replace tie rod ends? Correct? Is there anything else that would be "mandatory" while I am in there? If so, please inform cause I only want to do this once. I am not building a show truck or looking for perfection, just a safe clean truck that drives in a straight line. Thanks much in advance!
1966 Chevy C-20 Fleetside Longbed
Photobucket pictures
"Better get busy livin' or get busy dying" ~ ...Morgan Freeman
Check everything, tierod ends, idler arm ,center link, both upper and lower control arm bushings. They may not all be bad, but check to play safe.
Tommy
59 apache 1/2t
261 short stepside
Tommy #773878 08/22/2011 12:47 PM
Check the inner and outer bearings also.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Check everything down there. You can replace things as you go along (Have the extra $) if they look ok now. You dpn't have to do everything now but the parts are old and are prone to failure.
