| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | OK folks...before I attempt to break something, does anyone here know for sure the rotation on the lugs for a 1.5 ton '46? Lefty/loosie -righty/tighty on both sides or did they do the wacky opposing rotation thing? Thanks in advance. | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | Not sure what your truck has. But sometimes the nuts with left hand threads will have an "L" stamped on them. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tango, your truck probably has Motor wheels and Motor wheel nuts (large washer under the hex of the nut), they are standard right hand thread, hope that helps. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Thanx All --- just hoping to avoid busting something. | | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | My 46 2 ton was normal rotation, rusty as all get out, but normal threads. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I only recall the 50's Buicks having LH threads on the drivers side only. Maybe others but thats all I've experienced. A strange arrangement for sure. Never saw it on trucks | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | My '59 F-350 has them. I don't remember if my Internationals do or not.
Dodge and Plymouth cars of the 50's and 60's were also set up that way. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | All three of my 2-1/2 ton TF trucks have 6-lug Budd Wheels with left threads on the left side. The studs are marked with a "L" stamped on the end. Mike B  | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Thanks to all. With no threads exposed and no apparent markings, it's really hard to tell which way they go. Will just have to proceed with caution. I' will relay what I find...hopefully without snapping anything off first. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | My 38 1 1/2 ton both sides left loose right tight. | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | If you want to be extra careful split one of the nuts to remove it, then you can check for sure what thread it is.....granted you will need to find another nut...but a lot easier than replacing a stud.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | my 41 1.5 ton has RH threads all around | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Thanks again to all. Just yesterday confirmed they are all "righty-tighty" (normal)on both sides. | | |
