7 members (Gdads51, GusG, Southerntruck, klhansen, Maybellene, walterhvogel, Hotrod Lincoln),
114
Mod | | | Forums66 Topics128,089 Posts1,056,422 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,726 24601 | | 24601 Joined: Nov 1995 Posts: 5,726 | After nearly two years of fighting the original distributor, today I finally got the newly rebuilt HEI distributor (Pertronix Kit) installed and the truck successfully started (Hambone at the key, me in the engine compartment). So, thanks to all of you who have been encouraging me through all of this. The truck runs again!!! There was a very cold Detroit 6-71 parked in front of it or we would have taken a road test. That will have to wait until the Green Leaker thaws out  Thanks for the support John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | | | | | | Joined: Oct 2007 Posts: 568 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 568 | darn glad to hear this John. Maybe some trees can be saved! | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Fill up the tank, wait for a cold-spell, then go spray down a hillside. Put some hay bails alongside, then hop on your toboggan and enjoy your very own luge course! Local Winter Olympics! It'll be HUGE!!! You can retire!!!  -Michael | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | John, curious about the distributor. Did it have a spark advance? Our truck seems to have the govenor tied from carb to distributor and there is no spark advance. It is very sluggish until it is hot then hard to start sometimes. Congrats on getting the old girl running again.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Nov 1995 Posts: 5,726 24601 | | 24601 Joined: Nov 1995 Posts: 5,726 | Cannonball,
It has a vacuum spark advance that is hooked to the governor. It *is* sluggish and wants to miss/cough a little when the throttle is pressed. Also, it sounds rough at low idle, but smooths out as the revs come up. I doubt I have the timing close yet (close enought o run, though). Also, I may not have the distributor set in just right, yet. It seems to be close to time with the vacuum advance in about the 6 oclock position (towards the carb). I thought before, it was in the 9 oclock position.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | It *is* sluggish and wants to miss/cough a little when the throttle is pressed. Also, it sounds rough at low idle, but smooths out as the revs come up.
Thanks John, I suppose these problems are not limited to the V6 engine. Ours does the same thing.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | John and Cannonball, Have you guys checked your mechanical spark advance to see if it's working? I had problems with my truck running poor and found the weights rusted to the plate due to moisture condensating inside the dist cap. Took things apart, cleaned everything up and sprayed some teflon lube on things and all is well. A quick check is to start the engine with your timing light hooked up and rev the engine and see if the timing mark advances as the speed goes up and then returns when you drop back to idle. Mike B  | | | | | Joined: Nov 1995 Posts: 5,726 24601 | | 24601 Joined: Nov 1995 Posts: 5,726 | Mike,
Good point. I checked it with the little vacuum pump thingy (I forget what it's called, but it's for bleeding the brake lines, etc) before I reinstalled the distributor but have not checked it on the truck.
Also, could it be bad gas?? That gas is nearly a year old ...
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | The bad gas certainly wouldn't help. Not sure if that's your entire problem, but could certainly be contributing to it. | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | Thanks Mike, I never thought of that! If the advance is not working, it would be quick to see! Thanks again!
| | | | | Joined: Nov 1995 Posts: 5,726 24601 | | 24601 Joined: Nov 1995 Posts: 5,726 | Update Tanker 51 pumped at Homecoming! Here's Tanker 51 running a booster line Mike B's truck is right behind Tanker 51, and that's Mike B showing our neighbor's son how to handle the line. I'm running the pump. The cool thing that happened -- after filling the tank (1,000 gallons) for the first time in about two years, the tank gauge started working again!! (I thought it had rusted together 3 years ago).
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | congrats John. When the stars line up the Stovebolt gods can and do shine on us..... sometimes!! | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | | | | | | Joined: Nov 1995 Posts: 5,726 24601 | | 24601 Joined: Nov 1995 Posts: 5,726 | Update ,,,
As Hambone so astutely noted, the truck had power issues ... no more! After Jimmy Quade suggested I take out the plugs and check for fouling (he thought one or two might be fouled), this morning I removed all six. ALL were incredibly fouled. Yikes! 6 new Autolite double platnums later (to go with the Pertronix HEI upgrade), the truck runs like it's on afterburner. Wow!
What a difference a set of plugs can make.
And the kid at Autozone who sold me the plugs this morning impressed me -- he seemed, for a teenager, pretty knowledgeable about such stuff. When I told him about the Pertronix, Flamethrower coil and everything else, he suggested I open the gap to .040 versus the recommended .035 to make the plugs fire hotter. Well, it seems to be working like a champ. Just a short test drive over to Milt's a bit ago was breathtaking. I didn't even have to split shift.
Happy boy!
JM
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Thats great! So are you drive it here tomorrow for the big picnic? | | | | | Joined: Aug 2001 Posts: 3,603 Moderator | | Moderator Joined: Aug 2001 Posts: 3,603 | Great to hear it is running Top Notch. Even better to hear that younger people are into old cars and trucks!
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I didn't even have to split shift. john, fill it up with water then drive over to the picnic and see if you need to split the shifts. good job  | | |
