0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77281 05/07/2007 5:46 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | a floor shift that works well , but noisy in second gear . what model & brand would this be ? what parts to replace & where to get them . thanks for any help . | | |
#77282 05/07/2007 9:40 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s the standard 3 speed made by Chevy. These were naturally noisey in thr lower gears but if it,s excessive they are easy to o-haul. If the syncro,s work O.K. & it doesn,t jump out of gear it probably needs bearings. They are readily available along with gaskets & seals at an auto parts store. If it needs some hard parts you will need to contact one of the trans. specialty shops like Fatsco trans. parts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#77283 05/10/2007 2:35 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | thanks for the help wrenchbender .  frank | | |
#77284 05/10/2007 7:57 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | My 39 pickup has a 4 speed. No synchronizers. (Someone posted you can tell them apart by the lock out lever for reverse.) It was very loud when i bought it, but i drained all the fluid and rinsed it out with mineral spirits. Refilled with the best 90w i could find. it seems much quiet now. but still sings in lower gears.
"It ain't a truck if you can't hose out the cab."
