0 members (), 80 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#77281 05/07/2007 5:46 PM
a floor shift that works well , but noisy in second gear . what model & brand would this be ?
what parts to replace & where to get them . thanks for any help .
#77282 05/07/2007 9:40 PM
Riding in the Passing Lane
It,s the standard 3 speed made by Chevy. These were naturally noisey in thr lower gears but if it,s excessive they are easy to o-haul. If the syncro,s work O.K. & it doesn,t jump out of gear it probably needs bearings. They are readily available along with gaskets & seals at an auto parts store. If it needs some hard parts you will need to contact one of the trans. specialty shops like Fatsco trans. parts.
1972 Chevy c10 Cheyenne Super
#77283 05/10/2007 2:35 PM
thanks for the help wrenchbender . cool frank
#77284 05/10/2007 7:57 PM
My 39 pickup has a 4 speed. No synchronizers. (Someone posted you can tell them apart by the lock out lever for reverse.) It was very loud when i bought it, but i drained all the fluid and rinsed it out with mineral spirits. Refilled with the best 90w i could find. it seems much quiet now. but still sings in lower gears.
"It ain't a truck if you can't hose out the cab."
