1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members, I have a 54 3100...I put my hood back on the truck and now when I go over a good bump my hood pops open, The safety latch catches keeping it from flying open. I know how to adjust the top spring...the question is...did I make it too tight that there is so much tension on the latch that it springs free? or is there not enough pressure to hold it down in the latch ..or is my latch adjusted too far back on the front grill...or a combo of all of them?
Just seeing if someone else has done this so I don't have to make an adjustment and go look for a bump to go over to see if it is done correctly. Thanks in Advance | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | You may want to read the tech tip about adjusting hoods. As I remember there was a paragraph on how to adjust that. | | |
