3 members (TexasJim50, Peggy M, TexasA&M48Truck), 105 guests, and 6 robots.
Topics128,094
Posts1,056,058
Members48,433
#772655 08/18/2011 4:52 AM
Members, I have a 54 3100...I put my hood back on the truck and now when I go over a good bump my hood pops open, The safety latch catches keeping it from flying open.
I know how to adjust the top spring...the question is...did I make it too tight that there is so much tension on the latch that it springs free? or is there not enough pressure to hold it down in the latch ..or is my latch adjusted too far back on the front grill...or a combo of all of them?
Just seeing if someone else has done this so I don't have to make an adjustment and go look for a bump to go over to see if it is done correctly.
Thanks in Advance
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Jimmi_V #772904 08/19/2011 4:30 AM
You may want to read the tech tip about adjusting hoods. As I remember there was a paragraph on how to adjust that.
