I haven't tried just recently, but I have tried my local parts stores as well as all the usual vendors and I forget whether it's the upper or lower control arm bushings just don't seem to be available. Going by the post above it's probably the lowers. Thanks for the part numbers Bill, I'll keep that for reference depending on what I do.
I know it seems silly to downgrade it to a 1/2 ton, but for the type of build I'm going for it makes sense to me if it isn't too much hassle. Sure, it would be easier to start with a 1/2 ton, but this was the first vehicle I owned and I intend to keep it around
Who knows, maybe I'll keep it just the way it is. At least I lucked out and got one with 4.11 gears in the rearend instead of 4.56, so I don't really
have to ditch the stock rearend.
