Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (cmayna, baldeagle, Hotrod Lincoln), 47 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#771338 08/14/2011 12:45 AM
C4
Offline
I just posted in the Gallery a link to pics of the truck I took today. My project is bigger then first thought, but they usually are. Like input on the looks of the frame to you guys with the knowledge. Should I box the rear or back half it? Also the PO made his rear trans mount, do you think it is safe for the
3 speed or should I look for the correct one? Gallery post is under my 54 3100 pics
Thanks all.
Pics
We lust for what we want, and weep for what we need.
C4 #771341 08/14/2011 12:58 AM
the trans cross member shouldn't be there, the trans is meant to 'hang' off the bellhousing, which is the rear motor mount, having the assembly [engine/trans] attached at 3 places isn't good .... rather than boxing rotten channels you should consider finding a good frame - also the bed cross sills should be replaced .... sorry for the bad news wink
C4
Offline
Thanks, I'll get rid of the rear trans mount. Not sure what to do about the frame. I know alot use the S-10 but I'd rather keep the straight axle in front. Might consider back halfing in a short Z-frame and run a 4-link or ??
C4 #771352 08/14/2011 1:55 AM
C4....check my answer on your other post.....basically I agree with Bill but there is "maybe and option".
That's the trouble with double posting.
Cletis #771421 08/14/2011 10:36 AM
Socket Breaker
Socket Breaker
Why posts are edited, moved or deleted. Please read before posting.
Notice of a post in another forum.
After you post in a specific forum, do not come to the General Truck Talk page and post a notice of it. This is known as "double posting". The people with the specific knowledge of that topic will find it in the proper forum.
The people with paint and body work experience tend to peruse that forum. The folks with mechanical experience hang out in the Engine Shop and the Crash Box Shop... and so on for each forum.
Such notices, or double posts will be deleted from General Truck Talk without warning or notification.
