2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
#769191 08/07/2011 2:10 AM
Yikes! Things you can't see in a ebay picture. Discovered I have a bent front axle. Can a not so straight axle be straightened? I have heard of some old school alignment guys bending the axle to fix alignment, you guy have any experience regarding this? Originally thought about a mustang II ifs, but thought I'd save some money and use the stock front end, so I already have new shocks, springs and sway bar. (Hard to go back to plan A) Any thoughts would be helpful. Thanks. truck picture
rrenner #769197 08/07/2011 2:29 AM
I still bend axles on 18 wheelers to correct camber problems. Bending yours would be no problem, but getting it straight would be difficult because it would probably be S shaped at the bend. Put an ad in the swap meet section. Lots of old axle beams are scrapped from parts vehicle. If someone near you has one, they would probably part with it for very little.
Double Yikes! Yes, that can be straightened, but getting all the angles back to spec would be hard. crenwelge is right on, camber was/is set on beam axles by bending, even in model T days. Find another axle, lots less grief! Good luck.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #769218 08/07/2011 3:25 AM
Man, that's hard to take. I agree with replace it. An ad in the swap meet might find you one you can haul off free.
Cletis #769242 08/07/2011 4:26 AM
PM sent. I believe I can help and not far from you.
Achipmunk #769947 08/09/2011 10:54 AM
I wonder how the heck that got bent. It would have taken a lot of force to do something like that.
1951 1 Ton Completed
Not if my wife was driving that truck.
~Jim
Had a bent axel on the '46. Sid's in Guthrie, OK fixed it right up and back to specs too.
46Sparky #770092 08/10/2011 12:03 AM
Sid does awesome work. He did a 4" drop on my axle.
Thanks for all the help guys, I found a someone in Macon not far from me with a complete front end. As far as how it got that way I am only guessing but it looks like maybe a chain was used to pull it from somewhere stuck, (no other front end damage like from a wreck.
