Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (jay d, Otto Skorzeny, Hotrod Lincoln, Youngin' Tut 59, carbking, Cletus1950, 2 invisible), 86 guests, and 5 robots.
Topics128,288
Posts1,058,546
Members48,491
#768718 08/05/2011 7:45 AM
Few months ago I promised some new photos when I got off tour and able to get my hands on my new baby
here they are
http://i3.photobucket.com/albums/y64/armorgolem/hearse/39side.jpg
http://i3.photobucket.com/albums/y64/armorgolem/hearse/driver2.jpg
http://i3.photobucket.com/albums/y64/armorgolem/hearse/passback.jpg
http://i3.photobucket.com/albums/y64/armorgolem/hearse/motor.jpg
http://i3.photobucket.com/albums/y64/armorgolem/hearse/thetow.jpg
After a nerve racking tow to the house I unloaded the goodies inside the truck.
3 door skin
2 front fenders
1 back
3 sets of back doors
2 sets of front doors
2 hood sets
extra window hardware
alot of trim
a spare tire
and alot of metal parts I dont yet know what they are
I'm going to start with getting the rust off, any suggestions?
ospho or grinder then prime it?
Found this info using Search
I'd just use a traditional sand and blast it then put a coat of decent epoxy primer on it. I'd stay away from trying to sand it because at it's age, I suspect it's pitted and you'll never get into the pits unless you sand a lot of the metal down. I guess if you didn't have access to blast it, you could sand it down then go back over with with a chemical, but that's a lot of work.
Golem, what a great project! I would sand/ abrasive blast or have it tank dipped. Definitely go with epoxy primer, as it won't start rusting again if you're not in a big hurry to finish it. Take lots of pics along the way, that is a rare truck smile
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Awesome,I have the same panel..1/2 ton short wheel base. Got mine out of MN.It was a "Dept of Roads" vehicle.After I took the first layer of paint off, you could see that on the doors.Get this the..the phone# was 48..lol.Keep us posted on the progress. Cheers
Wow, what a cool truck. You can't help but be taken by its looks!
I would try some 3M stripper discs on a drill to see what you have in several places. The discs don't affect the metal but they will take off surface rust, paint and bondo. If money were no object I would dip it. Man, the sides of that beasty look really straight.
1951 1 Ton Completed
...ditto what the others said. Man, I love those back windows on that syle. Cool cool cool. That will be one sweeeet ride.
Thanks for all the input guys! exactly what I needed to hear
The lines on her are perfect, just a few rust holes and dents here and there but I really lucked out.
I'm going to look into dipping in my area
Definatly keep everyone up to date with the progress
If the shortcut actully worked it would be called "the way"
