0 members (),
125
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | My 53 had been converted to electric wipers, which work well. However, the kit used a round knob, very un-stock, with the word "Wiper" engraved white on black.
I have an original correct maroon knob, but I am baffled as to how to mount it to the shaft that comes through the dash. The knob has a much larger inside diameter, and no set screw or splines. The switch shaft is much thinner, and has a flat for a set screw. I don't want to just JB weld the thing together.
Any ideas? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | creative adaptation is a requirement for anyone wanting to 'hide' updates to an old rig .... sounds like the addition of a set screw to the knob along with some judicious sleeving [small copper tube?] might do it
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I put the factory switch back in the dash and then hid the one you describe under the dash it looks stock but is easily turned on since I know where the switch is. I located mine in one of the existing holes in the dash below the radio area. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Newport claims to sell an adapter the will let you use stock bezel and knob ...click.. I would call them to confirm first. The adapter in the pic on thier web site dose not look like it will work to me. I mounted the modern switch under dash and used a flex drive cable using stock bezel and knob drilled for set screw. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | harryr, looks like you may have solved the problem.
DADS, that is pretty much the way I would do it, looks good.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I did what Brad did, hide the new-fangled knob. | | |
