7 members (39Master85, kades51, Dennys28, baldeagle, Hotrod Lincoln, Otto Skorzeny, dt235sd), 73 guests, and 3 robots.
Topics128,180
Posts1,057,149
Members48,464
My 53 had been converted to electric wipers, which work well. However, the kit used a round knob, very un-stock, with the word "Wiper" engraved white on black.
I have an original correct maroon knob, but I am baffled as to how to mount it to the shaft that comes through the dash. The knob has a much larger inside diameter, and no set screw or splines. The switch shaft is much thinner, and has a flat for a set screw. I don't want to just JB weld the thing together.
Any ideas?
creative adaptation is a requirement for anyone wanting to 'hide' updates to an old rig .... sounds like the addition of a set screw to the knob along with some judicious sleeving [small copper tube?] might do it
I put the factory switch back in the dash and then hid the one you describe under the dash it looks stock but is easily turned on since I know where the switch is. I located mine in one of the existing holes in the dash below the radio area.
Thanks for the replies. I got brave and drilled the knob, and hacksawed a slot into a small-diameter bolt. Stay tuned.
http://share.shutterfly.com/share/received/welcome.sfly?fid=1907ac0c0c7f2c96&sid=8AZOGLNu0bMmQp
Newport claims to sell an adapter the will let you use stock bezel and knob
...click..
I would call them to confirm first. The adapter in the pic on thier web site dose not look like it will work to me.
I mounted the modern switch under dash and used a flex drive cable using stock bezel and knob drilled for set screw.
harryr, looks like you may have solved the problem.
DADS, that is pretty much the way I would do it, looks good.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Leo Offline
Moderator
Moderator
I did what Brad did, hide the new-fangled knob.
Moderated by  ndkid275, Phak1
