| | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | Just curious what method other Bolter's prefer. Do any of you use a bleeder kit when bleeding brakes? The kind with a hose and container, or do you not worry about it and just deal with the mess?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I have found that most of the bleeder kits you find on the shelf at the parts store don't even fit the bleeder nipple.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Make your own receiver bottle or buy one. I have a home-made bottle for Type 5 and a cheap kit for standard brake fluid (see below). I use the $5.99 bleeder kit (often on sale for about $3) and it keeps the fluid off the ground and off parts. A small piece of tubing from any hardware store is needed to match the bleeding valve/nipple. This Motive Pressure Bleeder 0102 makes it an easier 1-person job. I had to buy this to properly bleed a hydrovac but I often use it (with one of the bottles) on my other trucks. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I do it one of two ways. Use a piece of vacummn hose to a bottle (with a little fluid in the bottle and the end of the hose down in it.... and I've found that I like the speed bleeders. They're a little price at 10 bucks a pair but they do work.
A couple of the kits I've tried only made me angry! | | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | Thanks for all of the input. It seems that the local parts stores do not stock any bleeder kits that are worth buying. I will just rig up a small clear hose (as I have in the past) and get by.
Thanks again.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | My Motive one works great. Best bleeder I ever had. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I am with Mapleleaf on this. The Motive is the best
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | Just bleed the brakes on my 1949 4400 with one I bought from summit. Worked well and sure made the job a lot easier.
1949 Chevy 4400 216
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I have used the Mighty-vac for years with good results. But the last time I used it, I think I was sucking air in at the bleeder screws, and ended up getting the wife to do the old push-and-hold. Boy, I can say a one-man system is better.....if it will work!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
