2 members (Gdads51, WICruiser),
83
Mod | | | Forums66 Topics128,143 Posts1,056,495 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76729 04/24/2007 2:52 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Still trying to find out exactly what my new toy is. It was manufactured as a 1951 4400 cab and chassis, but the engine ID didn't seem to make much sense.
The number next to the distributor appears to be IOI 8359 F54X. The 8359 and F54X seem to be consistent with an engine that was manufactured in 1954, but the IOI and X after F54 were puzzling.
Then I found out that the block casting number is on the passenger's side in front of the fuel pump. So I went out to look at that and there is an aluminum plate covering the number that reads "Rogers Remaunfactured Engine". How nice.
It isn't a 216 based on the pushrod cover and valve cover. The cylinder head casting number is 3836848, which seems to be fairly common, with GM 30 below it. Does the GM 30 mean anything?
Other info on the aluminum plate is 25541, which I assume is a Rogers serial number. There are also three small, hard to read, numbers stamped into the plate on the fan end. I can't tell if they are complete or not. At the top is a C60, under that is a 030, (overbore?) and below that is a 010 (bearing oversize?)
I don't suppose that anyone out there ever worked for Rogers Engine re-manufacturing?
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
#76730 04/25/2007 3:46 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would bet the aluminum plate and all of it's markings are unique to the builder/machine shop of the day. If it's still fresh, it sounds like you got a good Stovebolt, Scott | | |
#76731 04/25/2007 5:19 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd guess the C60 is actually .060 and that is the over bore. The 030 and 010 would be rods and mains but I don't know which. It was probably painted on the aluminum when it was installed. | | |
#76732 04/25/2007 5:44 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Sounds like a 235. May be a 261 with a 235 head, but probably not.
Is the water pump in the block or mounted to a plate that bolts onto the block?
#76733 04/26/2007 2:04 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | The water pump is external to the block.
I also checked for 'captain's bars' near the starter and didn't see anything like that, although I really don't know what I was looking for.
#76734 04/26/2007 4:39 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's a 235, Flint plant, 3100 series for original application.
Bill Burmeister | | |
#76735 04/27/2007 2:56 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Back in my teens I remember Rogers Reman's as being top of the line. I don't know if they went out of business or was bought out? They did good work. The rebuild sounds like .060 overbore and 30 on the rods and 10 on the mains. I don't believer rebuilders back then would go 30 on the mains but not sure. Sounds like you got a nice one. | | |
#76736 04/27/2007 3:49 AM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 |
#76737 04/27/2007 10:10 PM | Joined: Jul 2006 Posts: 32 Junior Member | | Junior Member Joined: Jul 2006 Posts: 32 | Also back in my teens,I believe that Rodgers Reman's sold engines through Sears,and others. | | |
