| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76701 04/24/2007 2:02 PM | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | What is the white container on the lefthand side of the photo? What was it used for? Click here for picture Thanks for your help! Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
#76702 04/24/2007 2:05 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | vacuume canister for wiper motor
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#76703 04/24/2007 2:31 PM | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Originally posted by carolines truck: vacuume canister for wiper motor That is what I thought. But when I was squinting, trying to read the label, it says "Overflow Condenser", *Caution* . which lead me to believe it was for something else..like for the cooling system.
#76704 04/24/2007 2:50 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | yeap you're right see the heavy hose at the rad cap and the cap is different than a normal cap. it allows water to pass thru the tube to the overflow
good catch Niagara
#76705 04/24/2007 3:35 PM | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | I don't understand the purpose of that device. A little 216 operates at such low pressures.
I figure it does nothing...it is just a fellow who is an "accessories junkie" and had to install it in his truck.
Perhaps the resident experts will chime in and share some knowledge about the operation of the item.... I sure hope so!
#76706 04/25/2007 3:42 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's just to catch what would normally burp out of the overflow tube and prevent messing up his pretty paint job, Scott | | |
#76707 04/25/2007 5:08 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
#76708 04/25/2007 2:42 PM | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Thanks Tim.
Do you happen to know what model years these units were available?
