1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#76701 04/24/2007 2:02 PM
What is the white container on the lefthand side of the photo?
What was it used for?
Click here for picture
Thanks for your help!
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
vacuume canister for wiper motor
Jim & Caroline
Quote
That is what I thought. But when I was squinting, trying to read the label, it says "Overflow Condenser", *Caution* . which lead me to believe it was for something else..like for the cooling system.
yeap you're right
see the heavy hose at the rad cap and the cap is different than a normal cap. it allows water to pass thru the tube to the overflow
good catch Niagara
Jim & Caroline
I don't understand the purpose of that device. A little 216 operates at such low pressures.
I figure it does nothing...it is just a fellow who is an "accessories junkie" and had to install it in his truck.
Perhaps the resident experts will chime in and share some knowledge about the operation of the item.... I sure hope so!
It's just to catch what would normally burp out of the overflow tube and prevent messing up his pretty paint job,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks Tim.
Do you happen to know what model years these units were available?
