| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | Hi I'm currently rebuilding a 283 out of a 65 Chevy 1/2 ton. I recently bought order a piston for the 283 and the front part of the piston (Where the rings are) slides right into the cylinder but the back is difficult to get it in, requiring a rubber mallet. Should the piston be this hard to get in? This is my first engine rebuild and I'm practicing on this 283 before I rebuild the one in my 1957 6100 Chevy. Any other tips would greatly be appreciated. Thanks | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Any markings on the top of the new piston that may indicate that it is oversized? i.e. .010, .020, etc. Also the piston should have specs regarding clearances. IIRC the clearance for cast pistons should be around .002 to .003. Best to check with the piston supplier. Your set up doesn't sound right. Pictures would be helpful.
SimS | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Are you using a ring compressor? Has the ridge ring been removed from the cylinder? | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | The markings on the piston is .30 over but when i ordered it from summit the specs were the same as the one in the book. The markings on the piston is 235np .030 10159.I do know that the front where the rings go are the same in diameter as the old ones, except the skirt on the new one is larger than the old ones. Yes Im using a ring compressor but i dont know what the ridge ring is . Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ridge ring is a cabon ring where the piston stops its upward motion. Some engines will have "more" of a ridge ring than others. You need a ridge reamer to cut that carbon ring out. | | | | | Joined: Feb 2004 Posts: 29,793 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,793 | Have you measured the cylinder diameter with an inside micrometer? The paperwork that came with the piston should give you a reccomended skirt clearance, and the cylinder might need to be honed for a proper fit. Never, ever assume a part will fit just because it's marked the same as the one that came out. Correct piston fit is extremely important and the normal clearance is approximately the thickness of one strand of hair. Not much room for error! We used to check piston fit with a long feeler gauge blade and a spring scale. Now it's usually done with a dial bore gauge and a micrometer. Jerry
