6 members (Bill Hanlon, UtahYork, Rusty Heaps, Gdads51, Joe Franken, Charles in CA), 69 guests, and 5 robots.
Topics128,179
Posts1,057,134
Members48,463
Folks -
I finally got the correct door latches from American Classic. I have the door relay strut thingie removed, and all of the screws holding the latch itself, but it's now held in place with the exterior door handle. I've removed the screw in the plate that mounts to the door itself, but..... I *DON'T* want to force anything and thought I'd check here instead of going caveman... TIA for any suggestions or ideas on what's hanging things up...
John, will this help???
http://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm0108.htm
hope you get it worked out. Say hello to Rose.
I would reinstall the screws until you get the handle out. The square shaft on the handle can turn in such a way that it prevents the handle from coming out. I can't remember the details but I saw the same thing. I think I had to move the lock a little with the inside remote in order to take the pressure off the shaft.
1951 1 Ton Completed
The door glass channel guide may have to be removed also
...pic...
Above pic is of a 50, not sure if your year is the same, but you can use a mirror through the lower access panel to inspect.
DADS50 is correct you usually have to remove the guide to get them out, almost for sure to get them back in since it would have to slide up under it. The square shaft over time basically molds itself into the door latch and can sometimes need a bit of persistence to get it to come out.
