0 members (), 100 guests, and 2 robots.
Topics128,157
Posts1,056,875
Members48,456
Went on a long cruise and started hearing noise from somewhere out back. Sounds like it's about the same revs as the wheels. Under power I don't hear it but coasting I do. Don't see any grease leaking (from being hot) from wheel bearings. Going to get car up to redo brake system next week. Yeah, it failed again also. So what do I do to find noise? Thanks.
What vehicle we talking about here?
Sorry, Camaro rear end. Streetrod, with 350 motor and turbo 350 tramsmission.
Riding in the Passing Lane
Pull the cover off & see what you have. There should be no side play in the carrier or the pinion brgs.
1972 Chevy c10 Cheyenne Super
Axle bearing going bad??....maybe little pieces of the spider gears inside? ... are you sure its not a front wheel bearing and the noise is traveling and sounding like the rear end?
With it sitting still see how much "play" you have back and forth in the driveshaft.
noise under coast condition is usually pinion bearings, although tooth pattern could also be a culprit.
Originally Posted by beltfed
Camaro rear end.
I might be barking up the wrong tree here but if your Camaro axle has a posi diff,I assume you've put additive in?
My friends axle in his '52 was chattering badly as he 'forgot',it quietened down considerably after he added the correct gear oil additive.
Just a thought.....
More pix on Flickr.
