3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | i just had my 47 rewired, just over 700 buck , new lights, wiring, whole truck,resistors, tail lites , changed over from 6 volts to 12 , and put in directionals, which it never had. was this a good price ?? nice neat job !
care to chat write back
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Did you do it yourself or have it hired out? Is it an original style cloth covered harness, or modern wire?
Kent | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Like Kent said... We need more details to make a fair assesment. Did the price include all parts and labor, including the lights? Did the 12 volt conversion include an alternator? Was that in the price?
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Did the guy do it right, with soldered connections, secured harnesses, correct color code? Or did he use crimp connections on all yellow wire and it looks like a bowl of spaghetti? | | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | yes to everything, i had a new alternator, and everything done with the right gauge wiring
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If a cloth covered harness was used and everything works OK it's not a bad price (good price actually) because the harness alone is almost that much. If a modern harness was used and everything was done right it's a fair price.
| | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | whew , thanks , and yaand he did a few other things to, likechange my pan gasket, and an oil leak ..........!thanks
