Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (WICruiser, Guitplayer, Southerntruck), 46 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#763350 07/18/2011 12:29 AM
i just had my 47 rewired, just over 700 buck , new lights, wiring, whole truck,resistors, tail lites , changed over from 6 volts to 12 , and put in directionals, which it never had. was this a good price ?? nice neat job !
care to chat write back
mickster #763370 07/18/2011 1:21 AM
Did you do it yourself or have it hired out? Is it an original style cloth covered harness, or modern wire?
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Like Kent said... We need more details to make a fair assesment. Did the price include all parts and labor, including the lights? Did the 12 volt conversion include an alternator? Was that in the price?
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #763405 07/18/2011 2:53 AM
Did the guy do it right, with soldered connections, secured harnesses, correct color code? Or did he use crimp connections on all yellow wire and it looks like a bowl of spaghetti?
Cletis #764570 07/22/2011 9:33 AM
yes to everything, i had a new alternator, and everything done with the right gauge wiring
mickster #764612 07/22/2011 2:57 PM
Ex Hall Monitor
Ex Hall Monitor
If a cloth covered harness was used and everything works OK it's not a bad price (good price actually) because the harness alone is almost that much. If a modern harness was used and everything was done right it's a fair price.
Tiny #764696 07/22/2011 10:27 PM
whew , thanks , and yaand he did a few other things to, likechange my pan gasket, and an oil leak ..........!thanks
