4 members (SmalltownTRKGuy, Otto Skorzeny, TrknGMC, TooMany2count), 106 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#76263 04/12/2007 7:04 PM
Hey Guys, aside from boiling the tank, any other suggestions for a "quick fix" I have a new gas line hose and I put a filter on it. Tank is dry to the bone and I hesitate putting any fuel in it. I was thinking of taking the compressor and "blowing" the gunk out. I am not quite ready to drop the tank yet (as I have other plans 1st) so I am looking at just a "for now" idea. Got any? ohwell I am looking forward to taking my Thing out for a spin this weekend! (my first time driving him!) grin
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
#76264 04/12/2007 7:20 PM
LOTS has been discussed about that very subject here at the 'Bolt.
To summarize for your reading enjoyment, there are 3 camps:
1) replace the tank
2) Pull the tank and take it somewhere to have it redone
3) Pull the tank and clean it out yourself with muriatic acid and seal it with gas tank sealer.
Here are some links to the discussions:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=007631
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=007622
As for the "Quick Fix", a fuel-grade rubber hose going into a 5 gallon gas can does work to get an engine running.
Just be careful, especially if you use a tippy gas can... eek
#76265 04/12/2007 7:26 PM
Quote
5 gallon gas can
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#76266 04/12/2007 8:50 PM
Riding in the Passing Lane
When you are ready for a perminant repair get a new tank. I,ve sent them out to have them cleaned & coated only to have more scale & the coating comeing loose.
1972 Chevy c10 Cheyenne Super
#76267 04/13/2007 6:04 PM
Removing all of the rust can reveal other issues, like holes! grin
A new tank is the long term fix, but as for gettin it out & about for "testing", I used a portable 3-gallon boat tank. Run the tube to your fuel line & set it in the bed or on the passenger side floor. They're cheap, very safe, & no sloshing fuel to worry about.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#76268 04/13/2007 9:41 PM
Ex Hall Monitor
Ex Hall Monitor
I've cleaned & coated several tanks & never had a problem with the coating failing. Those who have trouble with liners failing usually don't follow the manufacturer's instructions.
If you have the option of a new tank being available & you can afford it that is probably the safest solution but not necessarily the BEST. :blat: grin
#76269 04/16/2007 7:40 PM
I just replaced my tank in my 57 3100 and it was the best move I could have made. When I saw the garbage that was in that tank I almost died. eek It was no wonder I was having ongoing problems with my carb and performance. The sender sock was filthy. I paid $139.00 + shipping for the tank. I dumped the fuel lines and added a new fuel filter. It runs like brand new. The local rad shop wanted $170.00 to clean and line my existing tank. It was a no brainer.
#76270 04/18/2007 2:55 AM
Can I ask where you got the tank at? 139 doesn't sound to bad.
#76271 04/18/2007 2:53 PM
I bet it was at Jim Carter. That's what I paid and where I got mine. Plus they add the correct threading if you're still using your original petcock like I did. Lost1953, if you have a good carb, I wouldn't chance using the old tank and ruining your carburetor. When I drained my tank, I about died too, I can't believe my truck drove. I still have the "OOZE" that came out of my tank. It looks like something that should be stored two miles under the Arizona desert. New tank, fuel lines, and carb, and my truck runs great. I would use a portable and temporary tank like Freq2002 suggested. I know you want to drive your truck, but don't make this the last time you do! Good luck, Jeff.
#76272 04/18/2007 5:46 PM
If you are replacing the tank, now would be a good time to consider placing the tank under the bed and out of the cab. It's more money, but it's just what your up for I guess.
Personally, if there is significant rust in the tank, I will opt for a new one and replace the rubber fuel lines and at least clean out the fuel lines. I also put in a inline fuel filter after the fuel pump.
#76273 04/19/2007 2:11 AM
Chey, I ran my '54 GMC with the old tank for about one hour and the engine got so gummed up I had to pull the head and do a valve job. I bought a new reproduction tank from Fat Fender in Fresno for about $ 160.00, now I have no worries about bad gas to gum up engine. I had the tank for my 1932 Chevrolet pickup cleaned out be a radiator shop but I'm a bit afraid to use it now since the bad experience with my GMC. Give me a call if you like.
Don
#76274 04/26/2007 2:46 AM
Thanks Don and all Fellow Bolters. Most appreciated. I sloshed the gunk around and drained it out. YA...oooooooze and rusty. Even air "bubbles" comming out. But I "think" I got most of it out. Ewwww...regardless. New tank is in the works. Will do when the time...I mean $$ is right...THANKS!!!!!! LOTS of Wonderful ideas guys!
Chey
LOST1953
More photos at MSN
#76275 04/26/2007 3:44 PM
I have good luck in the past cleaning tanks that had some varnish but no rust by using pea gravel and water and sloshing it around in the tank.I would do this several times and clean it using mild soap and water and then let it dry.Just my 2 cents.
