1 members (GMCJammer51), 153 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#760311 07/06/2011 11:24 PM
I need to find out what engine is in my (new) 1948 panel truck. The vin # is 6fsh2035 which tell me it is 1 ton but not the size of the engine. I can't find anything on the motor or pan. There is B50 B48 B50 E218 stamped on the motor but not sure what they or for. Also New Mexico #13--Rod 030--Main 010 on the stamped plate. Did they just use the 216 in 1948 1 ton. One other thing is where did they have the license plate. I hate to drill into the door if that is not where it should be. I am trying to keep original as I can. Thanks For Your Help
first48 #760368 07/07/2011 2:50 AM
It sounds to me like maybe someone has changed the engine to maybe a 235. Is the valve cover held on by two bolts that come through the top of the valve cover or by screws around the lip of the valve cover?
I don't have anything to run the numbers but I suggest you post this inquiry in the Engine and Driveline forum. Not everyone visits here in the welcome center.
Welcome to the Stovebolt. Your at the right place for information and help with your problems. Just post in the most appropiate forum and you'll be surprised. Good luck.
Oh, you may want to ask the License plate question in the General truck forum.... or maybe the paint and body? Either way you will get answers!!
first48 #760371 07/07/2011 2:57 AM
first48 welcome to the Forum... The VIN Buster did decode your truck as
Serial # : 6FSH2035
Mfg Date : August,1948
Model : 1 ton
Wheelbase : 137 inches
Plant : Oakland,
Block casting number, raised numbers found at the upper right of the starter, if you post this # we can tell you more about your engine... The E218 = May 21 48 if it is a 216 ... A 216 will have two studs coming out of the top of your valve cover...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
healingbear #760515 07/07/2011 4:59 PM
Thanks for getting back. There are 4 screws holding the cover on. 2 on each side.
The rised #s found by the starter are what looks like
B50 B48 and B50 i think.
Thanks again
Achipmunk #760517 07/07/2011 5:04 PM
Thanks for your help
The engine has 4 screws holding down the cover. Thanks again and I will inquire in the Engine and Driveline forum. Thank again and would love to have mine look half as good as yours. Loved it.
first48 #760537 07/07/2011 6:54 PM
first48 with 4 screws holding the valve cover on you do not have a 216... Find the Engine Cast # like this one and post it in the Engine Forum and we will be able to tell what engine you have... Many of these old trucks have replacement engines in them... Heck mine is one its third one!!!
Achipmunk #761483 07/11/2011 4:17 PM
Thanks for helping and I know this might not be the place to find out but I signed up on photobucket but how do I get them on site. It might be easy if you know what you are doing but if am struggling there must be others. Thanks for what ever you can do.
first48 #761523 07/11/2011 7:50 PM
welcome, you might stroll thru
here
if you have any questions post in the IT section
Redryder pix
My Hotrod
