1 members (Shade Baby), 152 guests, and 8 robots.
Topics128,106
Posts1,056,214
Members48,436
#759992 07/05/2011 6:34 PM
Folks -
We got Matilda home from the ranch after having some help knocking out dents in the roof of the cab. Need to replace window regs and door parts. Are the cabs and doors, etc the same btw 1 tons and the lighter trucks? LMC and a couple of other vendors I called pretty much blew me off and said to check with a mechanic. Durrr... Also, door glass? I'd appreciate anyone that can share the finer points. She's a 47 AD...
TIA,
the cabs and any related pieces like door internals are the same on any conventional cab for the year .... front clip is the same 1/2T to 1T, fenders change for the 1.5T and up
Everything on the cab, for every AD truck, unless it is a COE, interchanges. 1.5 & 2 tons the front clip changes.
47-50 doors are the same
51 doors are unique
52-55S1 doors are virtually the same but some odds and ends for the 54/55S1 are different
Front fenders are same 47-53 1/2 to 1 ton, 1 1/2 to 2 ton
54/55S1 are the same just as the older
Beds are same 47-53
54-55S1
Hoods are interchangeable for 1/2 - 1 tons but emblems change and '54-55S1 will bolt on the older trucks but the front emblem mount is completely different, same as the 1 1/2-2 tons
Probably some other odds and ends, too.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
i see that LMC and like them only care about 1/2 ton and 3/4 ton but 1/2 3/4 and one ton are lite,duty trucks , no one not remaking the one ton emblems or the emblems for the trucks that had the campers on the trucks
Moderated by  Dusty53
