9 members (Gdads51, frogfarmer, JoeDude, Jon G, TexasA&M48Truck, dt235sd, rfs56trk, Hotrod Lincoln, gswbbc),
137
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 12 New Guy | | New Guy Joined: Jan 2008 Posts: 12 | will a 250 bolt up to my 1950 three on the tree and mount in my truck | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | No, not directly. The 250 will not bolt up to the 1950 bell housing. I believe that the old tranny will not bolt to a modern bell housing without a spacer to adapt from the bore of the modern bellhousing to the input bearing housing outside diameter of the tranny.
A 3 speed of the same vintage as the engine makes the swap easier, but then you have to deal with the torque tube driveshaft and differential.
This swap is not easy, but not impossible.
Others feel free to chime in with things I have missed. | | | | | Joined: Jan 2008 Posts: 12 New Guy | | New Guy Joined: Jan 2008 Posts: 12 | thanks guess i will have to fix my 235 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The trans bolt pattern your truck has started in 1948 on trucks and is the same pattern that the passenger car started using in 1955. You can use a bellhousing for the 250 but you will still need to fab mounts.
See the USA in your vintage Chevrolet! My Blog | | |
