0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, When I got my 1 ton it came with windshield washer jets and a button (under the dash) to control the vacuum operated windshield washer, but the washer reservoir (Mason Jar) and mounting bracket were no longer on the truck. I recently got a jar and the bracket. The mounting screws on the bracket don't seem to line up to any existing holes. My firewall does have a lot of holes. I believe that windshield washers were an aftermarket only accessory. So I have a few questions. 1. Is there a diagram that shows what holes came in the firewall of an AD truck, and what they were for (different heaters, etc.)? Did the holes change from year to year? I would think that to do a correct restoration, one should fill all the non-factory holes and leave all the factory holes. 2. Were there different styles of the brackets for washer reservoirs? I think that they were made by Trico. Maybe I can't find the holes because I have a different bracket. Thanks! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes there is a diagram it is in the 1947-54 Factory Assembly Manual sold by a host of vendors. It states what all the holes are for in Section 1 Sheets 3.19-20-21 the correct one for your truck is 3.19 (close enough for reference anyway). Next it does not show the washer detail but the 1948 or similar years Accessory Installation Manuals will. The kits are dealer installed and appear in the option guides and salesman data books. The kits came with instructions (detailed measurements for drilled or existing holes)and all hardware to install they are a package that comes with everything needed to install that particular accessory. There are different brackets and styles for different years also there were aftermarket kits sold by companies like Trico and others. I would be happy to mail you photocopies of any of the information I have. I also have numerous pictures of the NOS install packages for some years. If interested send me a PM.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | No windshield washers for the ADs. Back in the day if you needed gas you wheeled into the Texaco and a smiling face asked, "fill her up?" Then he swept you floorboard out and washed your windshield. When that service to the windshield (windscreen for Jock)became obsolete the manufacturers started offering as an option, a crude kind of washer. My mother's 56 Ford had a rubber bag hanging under the dash and a foot pedal to press that mashed the bag and squirted a bit of water on the windshield. It didn't work worth a hoot but it was a start. Now if you don't like stopping to wash you windshield you will need to buy an after market job. Windshield Washers
~Jim
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | GM accessory windshield washers were available for Advance-Design trucks. There were two designs, pre-1954 (47-53) and 54/55. The earlier style shows up on eBay infrequently. I have never seen the a complete set of parts for sale for the 54/55 design (but I know people who have put together sets of parts or have some how found full sets from NOS parts vendors/finders). The 54/55 design has a foot-pedal that actuates the washer spray and also actuates the wipers (via a cable connection to the vacuum motor). No one seems to have information if/how the 54/55 washer actuates the 2-speed 6v electric wiper motor. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I stand corrected. Thanks for adding to our history.
~Jim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Amazing history available on this site!!!! Thanks for taking the time to share with the other newbies. I have no idea what other treasures that are here that I have not stumbled upon. Peter | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | For anyone interested I have copied the instructions for installing the factory accessory windshield washer assembly for 1947-53 trucks onto a pdf. If you would like them send me a PM and I will forward them along. | | |
